[GRASS-dev] Re: [GRASS GIS] #1011: How to test grass6 webpage, instructions need edits
GRASS GIS trac at osgeo.org
Mon Mar 15 16:13:30 EDT 2010
  Reporter:  JohnTate     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  Website      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  wiki edits
  Platform:  Linux        |         Cpu:  x86-64
Comment (by hellik):
 Replying to [ticket:1011 JohnTate]:
 > For: http://trac.osgeo.org/grass/wiki/HowToTestGrass6
 > Whilst testing the OSGeo Live DVD (vm version) I followed the
 instructions to further test the installation. I am not a user of the
 wxGui so it was interesting. Errors or improvements:
 > 1) In section 'Using wxPython graphical user interface: Digitizing: line
 3' I would suggest that zoom is done to the elevation map after the
 addition of the ortho map (the ortho overlies it anyway). This way the
 selection of a house to digitise will be in the map area when 3D vector
 and visualisation is done. The first house I picked was outside of the
 elevation map and subsequently wasn't in the 3D visualisation, so had to
 start again.
 > 2) Same section: line 5, there is no Tools menu. I looked for while (I
 could have used v.digit but wanted to follow the instructions as a new
 user would). I suggest text 'Select Digitise from the drop-down box in the
 top-right corner of the map window (currently set at 2DView)'. Unless I am
 missing something obvious!
 > 3) Same section: line 8, very minor but for consistency, "Quit" instead
 of "Close". I could change this myself but as other bits needed
 verification, have left it here.
 > Hope you don't think I am being too pedantic,
 > Cheers
 > John
 I've tested this a little bit in Wingrass.
 under
 http://trac.osgeo.org/grass/wiki/HowToTestGrass6#SeeAlso
 there are some examples for raster, vector, image processing and
 interpolation actions (grasstestrast.txt, grasstestvect.txt,
 grasstestinterp.txt, grasstestimg.txt).
 most of them are working under Wingrass.
 if you are assuming in the windows world the default is the WinGrass-WxGUI
 (only with the wx-gui-commandline and without a msys-command-line or any
 other command-line), following are not working in the examples:
 - d.erase: it's not implemented in the wx-gui-command-line, you have to
 use the erase-button in the wx-gui
 - there are some examples where ''echo'' is used (e.g. echo "634886 224328
 1"|v.in.ascii out=fire_pt fs=space), this isn't working from the wx-gui-
 command-line
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1011#comment:1>
