[GRASS-dev] v.krige error
Jan Trochta j.trochta at gmail.com
Tue Mar 16 06:34:54 EDT 2010
Thanks for helping,
If you will need testing or anything post me mail..
Jan
Anne Ghisla píše v Út 16. 03. 2010 v 12:17 +0200:
> On Tue, Mar 16, 2010 at 11:58 AM, Jan Trochta <j.trochta na gmail.com> wrote:
> > Hi list,
> > I would like to test new module v.krige, but after launchig I get error:
> > Traceback (most recent call last):
> >  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 419, in <module>
> >    sys.exit(main(argv = grass.parser()))
> >  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 386, in main
> >    logger = grass)
> >  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 265, in Run
> >    globals()["InputData"] = self.ImportMap(input, column)
> >  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 164, in
> > ImportMap
> >    coordinatesDF = robjects.r['data.frame'](x =
> > coordinatesPreDF.r['coords.x1'][0],
> > AttributeError: 'DataFrame' object has no attribute 'r'
> > Rpy2 is installed, Opensuse 11.2,
> > Its my mistake or bug in module?
> Hi Jan,
> it's a bug in the module - not known to me until now, but
> unfortunately I never tested v.krige on opensuse.
> At the moment the module is working on GRASS trunk and afaik on 6.5
> branch, except for the plot popup window.
> Thanks for the report and sorry for inconvenience... will look at it asap.
> all the best,
> Anne
> > thanks
> > Jan Trochta
> > grass-dev mailing list
> > grass-dev na lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
