[GRASS-dev] r.gwflow
Soeren Gebbert soerengebbert at googlemail.com
Fri Mar 19 16:27:44 EDT 2010
Hello Massimo,
unfortunately i am not able to reproduce the segfault, because i do
not run a 64bit system. Does this error also occurs when you start
r.gwflow with parameters, so without gui generation?
Best regards
Soeren
2010/3/19 Massimo Di Stefano <massimodisasha at gmail.com>:
> Hi,
> curiose i tried to compile grass on debian enabling "glw" supprt
> to give a try to the module "r.gwflow"
> the build go ahead without errors but ring to run "r.gwflow" i received a segfault
> teing with gdm i have this log :
> GRASS 6.5.svn (WGS84_33N):~ > gdb r.gwflow
> GNU gdb (GDB) 7.0.1-debian
> Copyright (C) 2009 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>...
> Reading symbols from /usr/local/grass-6.5.svn/bin/r.gwflow...done.
> (gdb) run
> Starting program: /usr/local/grass-6.5.svn/bin/r.gwflow
> [Thread debugging using libthread_db enabled]
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff7bbab71 in G_recreate_command () at parser.c:2857
> 2857            if (opt->answer != '\0' && opt->answers[0] != NULL) {
> (gdb)
> (gdb)
> i'm running grass 6.5 svn on debian sid._______________________________________________
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
