[GRASS-dev] r.gwflow
Massimo Di Stefano
massimodisasha at gmail.com
Fri Mar 19 21:42:19 EDT 2010
yes that's my fault ... sorry.
i have both 6.5 - 7.0 installed and i openend the wrong help file.
following the 6.5 help the command line examples works nice
and i'm able to visualize the data in paraview without any problems.
( the segfault affects only the gui )
thanks,
Massimo.
Il giorno 19/mar/2010, alle ore 22.44, Glynn Clements ha scritto:
> Massimo Di Stefano wrote:
>> it's my first attempt to use r.gwflow
>> so i have to read it's manual page
>> with more carefully.
>> i tried a fast try following the help page, but seems i did something wrong, see the logs :
>> http://www.geofemengineering.it/data/r_gwflow.txt
> Says:
>> Sorry, <vx> is not a valid parameter
>> Sorry, <vy> is not a valid parameter
>> Sorry, <budget> is not a valid parameter
> These options are only present in 7.0, not in 6.5.
> Glynn Clements <glynn at gclements.plus.com>
