[GRASS-dev] r.gwflow
Sat Mar 20 14:58:02 EDT 2010
Soeren Gebbert wrote:
> Problem solved in Revision 41496.
So ...
> > param.type = G_define_option();
> > param.type->key = "type";
> > param.type->type = TYPE_STRING;
> > param.type->required = NO;
> > param.type->answer = "confined"; <----- this parameter is the reason for the segfault
... is this statement incorrect?
Because this appears to have nothing to do with  r41496.
