[GRASS-dev] [GRASS GIS] #1021: v.in.ogr: multiple files are merged
when using only dsn= without layer=
trac at osgeo.org
Sun Mar 21 13:12:53 EDT 2010
#1021: v.in.ogr: multiple files are merged when using only dsn= without layer=
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Keywords: ogr | Platform: All
Cpu: All |
When pointing v.in.ogr to a directory which contains several SHAPE files
(or presumably
other OGR supported files) by defining dsn= without using layer=, it
imports all files
into the output map which is typically undesired.
Suggestion: add a check if the DSN is file based and if layer= was
omitted, in
that case refuse to importand complain about the missing layer= parameter.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1021>
