[GRASS-dev] Re: [GRASS GIS] #1022: v.out.ogr fails on wi7
GRASS GIS trac at osgeo.org
Sun Mar 21 17:10:18 EDT 2010
  Reporter:  MilenaN      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  default      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  v.out.ogr, wingrass
  Platform:  MSWindows 7  |         Cpu:  x86-64
Comment (by hellik):
 Replying to [ticket:1022 MilenaN]:
 > Using RC6/wxgui export to shapefile fails:
 > v.out.ogr -c input=boundary_county at PERMANENT type=line dsn=c:\
 olayer=pppppppppppppppp
 > ERROR 1: Failed to create file .shp file.
 > ERROR 4: Failed to open Shapefile `c:\pppppppppppppppp.shp'.
 > ERROR: Unable to create OGR layer
 > on winxp it works ok
 dsn=c:\
 are you sure that you have write permission in c:\?
 I've tested this on my WinVista-box, v.out.ogr in c:\ fails also, but for
 example in dsn=C:\wd\testgrass v.out.ogr works.
 the behaviour of write permission in c:\ has changed from WinXP to
 WinVista/Win7.
 Please can you test v.out.ogr in C:\wd\testgrass or in an folder on
 another drive?
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1022#comment:1>
