[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Sat Mar 27 06:22:07 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hellik):
Replying to [comment:14 hamish]:
> for me on 32bit linux I get this output for that line (spearfish's
elevation.dem)
evelation.dem:
rows: 466
cols: 633
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
Reading data from <elevation.dem> to stream </var/tmp//STREAM_qylbyz>
100%
/var/tmp//STREAM_qylbyz: length = 1179912 sizeof(T)=4
total elements=294978, nodata elements=2661
largest temporary files:
FILL: 15.75M (16518768) [294978 elements, 56B each]
FLOW: 22.30M (23385360) [292317 elements, 80B each]
Will need at least 44.60M (46770720) space available in /var/tmp/
COMPUTING FLOW DIRECTIONS
and with spearfish's elevation.dem on WinVista32
r.terraflow --verbose elevation=elevation.dem at PERMANENT
filled=floodedelevdem direction=flowdirrast swatershed=sinkwatershrast
accumulation=flowaccrast tci=topoconvrast memory=900
MFD flow direction
Memory size: 900.00M (943718400) bytes
C:/Users/syringia/AppData/Local/Temp/STREAM_a03800: length =
17179869184 sizeof(T)=1
D3/3: nrows=466 ncols=633 stream_len()=0
17179869184 sizeof(T)=0
Assertion failed: nrows * ncols == str->stream_len(), file
grass2str.h, line 146
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:16>
