[GRASS-dev] [GRASS GIS] #1048: wxgui: g.region: can't reset `rows='
nor `cols='
trac at osgeo.org
Sun May 2 09:54:12 EDT 2010
#1048: wxgui: g.region: can't reset `rows=' nor `cols='
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Keywords: | Platform: All
Cpu: All |
1. Run g.region from wxgui.
2. `Resolution' tab.
3. Change the `Number of rows in region'.
4. "Oops, I wanted to edit the resolution instead."
5. Edit the `Grid resolution 2D (...)' field as you intended too.
6. You can't reset `rows=' in the GUI now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1048>
