[GRASS-dev] Re: [GRASS GIS] #1045: strange behaviour in v.net.path
trac at osgeo.org
Mon May 3 13:37:30 EDT 2010
Reporter: manuele | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords: network analysis
Platform: Linux | Cpu: x86-32
Comment (by mlennert):
I can't reproduce this with the North Carolina demo data set:
v.net streets_wake points=firestations operation=connect thresh=200
out=streets_firestations
echo "1 15 64" | v.net.path streets_firestations afcol=FT_COST out=myPath
echo "1 15 64" > mypaths.txt
cat mypaths.txt | v.net.path streets_firestations afcol=FT_COST
out=myPath2
v.db.select myPath
cat|id|fcat|tcat|sp|cost|fdist|tdist
1|1|15|64|0|21.379|0|0
v.db.select myPath2
Your data is not usable as you don't define the projection system it is
in, nor is the attribute table containing the arc_cost column attached.
Best would be to either reproduce the bug with the demo dataset, or
provide your example data as a complete location, including the sqlite
database, or with a dbf attribute backend.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1045#comment:1>
