[GRASS-dev] [GRASS GIS] #1053: After abort command v.surf.rst from wxGUI vector output of devation (devi) couldn´t be removed, or overwrited
trac at osgeo.org
Wed May 5 02:40:43 EDT 2010
Reporter: jeleniste | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: v.surf.rst, wxgui, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Removing vector <devi at hutur_DEM>
Tabulka <devi> připojená k vektorové mapě <devi> neexistuje
Nelze smazat soubor <C:\Documents and Settings\BRMichalek\Dokumenty\GIS
DataBase/JTSK/hutur_DEM/vector/devi/coor>
couldn't be removed
<devi> nothing removed
I run command v.surf.rst with bad parameters (so hungry for time) after
some time i try abort command by button stop, after change of parameters,
command don't run because can't overwrite vector map of deviation (fůag
-overwrite was used), I try to use module g. remove, but layer devi is
broken and module g.remove isn't able to remove this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1053>
