[GRASS-dev] [GRASS GIS] #1055: db.select can´t found columns generated by v.rast.stats with dbf driver
GRASS GIS trac at osgeo.org
Wed May 5 10:57:52 EDT 2010
 Reporter:  jeleniste       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.0
Component:  default         |     Version:  6.4.0 RCs
 Keywords:  dbf, db.select  |    Platform:  MSWindows XP
      Cpu:  Unspecified     |
 if I try to use in sql parameter in where clausule column generated by
 v.rast.stats it return me error, column cant be found, but is presented in
 table output (if not used in where clausule), using in list of columns for
 select returns me error to
Ticket URL: <http://trac.osgeo.org/grass/ticket/1055>
