[GRASS-dev] [GRASS GIS] #1056: OverflowError : long int too large
to convert to int
trac at osgeo.org
Wed May 5 11:07:19 EDT 2010
#1056: OverflowError : long int too large to convert to int
Reporter: scizmeli | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Hello,
I am running GRASS 6.4.0RC5 on Ubuntu Karmic.
I have been given a Mapinfo .tab vector file (polygons of administrative
divisions of the city of Istanbul). Although the units seem to be in
meters, the layer does contain no projection information. After many days
of trial/error, I was unable to find its projection so I finally decided
to rectify it so that I can use it with other GIS layers (EPSG 23035).
I first imported the layer into a XY location. I then created a
georeferenced location (EPSG 23035) and started GRASS in it. When I start
the georectifier, it all seems OK (except the fact that I had to first set
the scale to 1:300,000,000 to be able to see the layer ;o(. any other way
to zoom into that layer?) and I was able to set many GPCs. When it was
time to go to bed, I saved the GCP's in a POINT file under the group I had
created and went to bed. The next day, when I relaunch the georectifier
under the same group, I get the following error :
And the unprojected layer never gets displayed. I cannot continue my work.
Trying the georectification with the same GCPs yield the same error as
well.
Is this a bug?
Let me know if I can furnish more info.
Servet
Here is part of the output of ogrinfo -so :
Had to open data source read-only.
INFO: Open of `mahalle.tab'
using driver `MapInfo File' successful.
Layer name: mahalle
Geometry: Unknown (any)
Feature Count: 639
Extent: (384799.325217, 4517717.000003) - (450634.029997, 4575689.999997)
Layer SRS WKT:
LOCAL_CS["Nonearth",
UNIT["Meter",1.0]]
Please find attached a gml extract of the dataset for your convenience. I
was able to reproduce the error with this gml layer as well :
ogr2ogr test.gml input.tab -f "GML" -where "fid in (1)"
Here is the full error message :
GISDBASE: /C_DRIVE/Users/user/Desktop/...
LOCATION_NAME: Istanbul_23035
MAPSET: PERMANENT
MONITOR: x0
GRASS_GUI: wxpython
File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 367,
in OnGeorectify
georect.GeorectWizard(self)
File
"/usr/lib/grass64/etc/wxpython/gui_modules/georect.py", line
198, in __init__
self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
File
794, in SetMapDisplay
self.list.LoadData()
File
1290, in LoadData
self.gcp.ReadGCPs()
File
991, in ReadGCPs
sourceMapWin.UpdateMap(render=False, renderVector=False)
File
"/usr/lib/grass64/etc/wxpython/gui_modules/mapdisp.py", line
811, in UpdateMap
self.parent.gismanager.georectifying.DrawGCP(coordtype)
File
881, in DrawGCP
5]})
File
1048, in DrawCross
self.Draw(pdc, drawid=self.lineid, pdctype='line',
coords=lineCoords)
File
404, in Draw
pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
File "/usr/lib/python2.6/dist-
packages/wx-2.8-gtk2-unicode/wx/_gdi.py", line 7191, in
DrawLine
return _gdi_.PseudoDC_DrawLine(*args, **kwargs)
OverflowError
Ticket URL: <http://trac.osgeo.org/grass/ticket/1056>
