[GRASS-dev] Re: [GRASS GIS] #1055: db.select can´t found columns generated by v.rast.stats with dbf driver
    trac at osgeo.org
    Wed May  5 15:19:13 EDT 2010
  Reporter:  jeleniste     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Database      |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  dbf, db.select
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:3 jeleniste]:
 > Try db.select sql = "Select cat,elev_n,elev_min from geo where=elev_n
 not NULL"
 it should be
 db.select sql="select cat,elev_n,elev_min from geo where elev_n not NULL"
 so without `=` after {{{where}}} keyword.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1055#comment:4>
