[GRASS-dev] [GRASS GIS] #1061: Merge DB connet/DB Login/DB Test in
one module
trac at osgeo.org
Sun May 9 10:02:52 EDT 2010
#1061: Merge DB connet/DB Login/DB Test in one module
Reporter: vesnikos | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-32 |
It just doesnt make sense:
With the first you set the connection, with the second you Log at the db
(in both you can choose the driver,) and with the third you test the
connection
Its a bit confusing
Ticket URL: <http://trac.osgeo.org/grass/ticket/1061>
