[GRASS-dev] Re: [GRASS GIS] #1059: wxGUI: No menu option for r.mapcalc
GRASS GIS trac at osgeo.org
Mon May 10 06:56:19 EDT 2010
  Reporter:  vesnikos  |       Owner:  martinl
      Type:  defect    |      Status:  reopened
  Priority:  major     |   Milestone:  7.0.0
 Component:  wxGUI     |     Version:  svn-trunk
Resolution:            |    Keywords:  r.mapcalc wxGUI
  Platform:  Linux     |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:11 mmetz]:
 > This is now no longer possible in grass7.
 r42183 was incomplete; this should be fixed by r42210.
 > r.mapcalculator is present in grass7, but as bash script, apparently it
 awaits translation to python?
 The consensus was that it wasn't worth maintaining. In 7.0, r.mapcalc uses
 G_parser(), so it can be run directly from the GUI without requiring a
 wrapper.
 > All the recent changes are done only to get a hit when searching the
 module in the wxGUI?
 r42183 had two parts: fixing the GUI menu, and cosmetic changes to
 r.mapcalc. The latter included renaming the input= option to file=, but
 overlooked the fact that it synthesises "input=-" when run without
 arguments (to preserve the historical behaviour). The change broke this
 behaviour; r42210 reinstates it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1059#comment:12>
