[GRASS-dev] [GRASS GIS] #1065: v.in.mapgen fails to load coastline from NOAA's National Geophysical Data Center
GRASS GIS trac at osgeo.org
Tue May 11 18:32:51 EDT 2010
Center
 Reporter:  vesnikos                   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  7.0.0
Component:  Vector                     |     Version:  svn-trunk
 Keywords:  v.in.mapgen, mapgen, NOAA  |    Platform:  Linux
      Cpu:  x86-32                     |
 when im trying to input a costline in mapgen format  taken from the said
 site, I encounter the following:
 v.in.mapgen  input=/home/nikos/datagis/coastline/6888.dat output=coastline
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 198,
 in <module>
     main()
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 129,
 in main
     outf.write(" %.8f %.8f %.8f\n" % tuple(map(float,point)))
 ValueError: invalid literal for float(): #
 GRASS 7.0.svn (wsg84):~/grass7/bin > v.in.mapgen
 in <module>
     main()
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 170,
 in main
     user = user, host = host)
   File "/usr/lib/python2.6/string.py", line 172, in substitute
     return self.pattern.sub(convert, self.template)
   File "/usr/lib/python2.6/string.py", line 162, in convert
     val = mapping[named]
 KeyError: 'proj'
 with the following command:
 v.in.mapgen -f input=/home/nikos/datagis/coastline/6888.dat
 output=coastline
 in <module>
     main()
 in main
 The file can be reached at :
 http://hotfile.com/dl/42431518/c2e8072/6888.dat.gz.html  (~780 kb)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1065>
