[GRASS-dev] diglib test.c fails on 64bit win
Martin Landa landa.martin at gmail.com
Wed May 12 01:27:22 EDT 2010
2010/4/13 Martin Landa <landa.martin at gmail.com>:
> 2010/4/12 Glynn Clements <glynn at gclements.plus.com>:
>> That should be fixed, then. On Windows, --enable-largefile has no
>> effect other than breaking the diglib test.
> then probably diglib test should be disabled on 64bit Windows machines
> or better to be fixed.
any chance to fix this issue?
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
