[GRASS-dev] diglib test.c fails on 64bit win
Wed May 12 07:11:47 EDT 2010
Markus Metz wrote:
> #ifdef __MINGW32__
> #define off_t off64_t
> #define fseeko fseeko64
> #define ftello ftello64
> #endif
> in config.h have any effect?
If you do that, you will also need to fix lseek() and stat().
Also, are there any cases where we pass an off_t to a third-party
library? Because that would require the library to use a 64-bit off_t
(this is one of the reasons why _FILE_OFFSET_BITS=64 has to be
explicitly enabled).
