[GRASS-dev] Re: [GRASS GIS] #491: grass7: cannot start grass with -text and no existing .grassrc7
GRASS GIS trac at osgeo.org
Thu May 13 01:35:53 EDT 2010
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  major        |   Milestone:  7.0.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 the old interactive text forms have been removed in grass7. either pass
 the path to the mapset on the command line or if none is given and you've
 had a previous session the last session will be used if no command line
 args are given and `GRASS_GUI: text`.
 of course the error checking, messages, and new text startup workflow can
 always be improved, you're not looking at the final product.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/491#comment:3>
