[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler neteler at osgeo.org
Fri May 14 08:51:48 EDT 2010
On Sun, Apr 18, 2010 at 10:44 AM, Markus Neteler <neteler at osgeo.org> wrote:
> I have tried to generate a new vector map with the new digitizer, but it fails:
This is still the case.
GRASS 6.4: A Python problem appears when generating a new vector map in
the digitizer (Start digitizer, new map, enter name, OK):
Unable to initialize display driver of vector digitizer. See 'Command
output' for details.
Details: 'NoneType' object has no attribute 'OpenMap' ()
GRASS 6.5: A different Python problem appears when generating a new vector map
in the digitizer (Start digitizer, new map, enter name, OK):
Reason: message=_("Unable to initialize display driver of vector "
  File "/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/toolbars.py",
line 1123, in StartEditing
DigitError: <unprintable DigitError object>
Markus
