[GRASS-dev] Re: python scripts and standard input
Massimo Di Stefano massimodisasha at gmail.com
Fri May 14 19:24:35 EDT 2010
the work-around :
> while 1:
>   try:
>       function()
>       break
>   except IOError:
>       sleep(0.1)
works,
but i have to add it for each grass command i'm running in the code.
Il giorno 15/mag/2010, alle ore 00.22, massimodisasha at gmail.com ha scritto:
> Il giorno 30/apr/2010, alle ore 02.39, Glynn Clements ha scritto:
>> Massimo Di Stefano wrote:
>>> actually i'm using :
>>> out = subprocess.Popen(['m.proj', '-o'], stdout=subprocess.PIPE,  stdin=subprocess.PIPE).communicate("%s %s" % (x,y))[0]
>> That will work on Unix, but Windows will complain due to the lack of
>> the .exe suffix. You can use grass.Popen() to get around that.
> thanks Glynn i adopted this way and it works (but i haven't tested on windows)
>>> This topic, maybe is good to discuss a problem i'm having about subprocess,
>>> please apologize me if it is OT, tell me to open a new thread.
>>> The error i'm having is strictly connected with subprocess and how grass handle it.
>>> The weird is that the error i'm having comes up only on OSX while on linux all works fine.
>>> this the error log  :
>>> File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/subprocess.py", line 663, in communicate
>>>  stdout = self.stdout.read()
>>> IOError: [Errno 4] Interrupted system call
>> This appears to be a bug either in Python's read() method for pipes or
>> in Python's subprocess module. The underlying read() is failing with
>> EINTR, which can happen if a signal is received during a blocking
>> system call.
>> Normally, you would configure the signal handler to resume any system
>> calls (unless you specifically want it to interrupt blocking calls,
>> e.g. implementing a timeout by setting a timer and having SIGALRM
>> interrupt the system call).
>> In this case, I would expect the code to just try again, rather than
>> raising an exception. EINTR and EAGAIN are "transient" errors, in that
>> a subsequent attempt will typically succeed.
> i'm tring to find a way to follow your suggestions.
> if "function()" is the subprocess action that give me error on osx
> maybe i can try something like :
> while 1:
>   try:
>       function()
>       break
>   except IOError:
>       sleep(0.1)
