[GRASS-dev] Re: [GRASS GIS] #1051: wxgui: SEARCH_PATH corruption
trac at osgeo.org
Sun May 16 14:09:04 EDT 2010
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by msieczka):
Replying to [comment:2 glynn]:
> Replying to [ticket:1051 msieczka]:
>> If maps of the same names exist in mapset1 and mapset2, GRASS will pick
the one from mapset1
>> although the current mapset is mapset2. This might lead to various
troubles.
> This isn't necessarily a problem. GRASS itself doesn't care whether the
current mapset is
> first in the search path, or even if it's in the search path at all.
According to my tests, the SEARCH_PATH file, if present, overrides the
default "current mapset 1st, PERMANENT 2nd, other mapsets next" behaviour,
up to even excluding any mapset from the search path. Mapsets' order in
the SEARCH_PATH file determines the search order too. Do the steps 1-3 in
#comment:description. Now:
4. Create a vector map: v.random out=point n=1.
5. Start a new session in mapset1.
6. Create a vector map of the same name as in mapset2, i.e. do "v.random
out=point n=1".
6. Back in mapset2 troubles begin:
a) v.info picks the map from mapset1 although we are in mapset2:
$ v.info -h point
WARNING: 'vector/point' was found in more mapsets (also found in
<mapset2>)
WARNING: Using <point at mapset1>
<mapset2>)
COMMAND: v.random output="point" n=1 zmin=0.0 zmax=0.0
GISDBASE: /home/grassdata
LOCATION: test_location MAPSET: mapset1 USER: pok DATE: Sun May 16
11:15:28 2010
b) same does g.region:
$ g.region vect=point
<mapset2>)
c) same does v.to.rast:
$ v.to.rast use=cat in=point out=point_rast
<mapset2>)
Loading data...
Reading features...
100%
Writing raster map...
100%
Converted areas: 0 of 0
Converted points/lines: 1 of 1
v.to.rast complete
Any module I tried prefers the "point" vector map from the first mapset in
the SEARCH_PATH (mapset1) rather the one in the current mapset (mapset2).
I understand what Glynn says in his furher comments in #comment:2, fully
second that, but getting back to the original subject: wxGUI's `Settings >
GRASS working environment > Mapset access' needs a fix.
I have attached a patch against SVN develbranch6, r42262. Please anybody
let me know if it's acceptable. In general, it's purpose is to make
'Mapset access' GUI work same as 'g.mapsets addmapset=/removemapset=',
which:
1. Doesn't allow the user to remove the current mapset from the
SEARCH_PATH.
2. The current mapset is always first in the SEARCH_PATH.
3. Treats PERMANENT as any other mapset AFAICT. PERMANENT is the second in
the search path only if the SEARCH_PATH file is not present.
4. Doesn't sort mapset names in the SEARCH_PATH file. Thanks to this, the
search order depends on g.mapsets add/remove commands sequence, thus can
be controlled from GRASS itself.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1051#comment:3>
