[GRASS-dev] Re: [GRASS GIS] #1070: cannot enter useful values to
r.param.scale curvature tolerance in wxPython GUI
trac at osgeo.org
Sun May 16 17:27:55 EDT 2010
#1070: cannot enter useful values to r.param.scale curvature tolerance in wxPython
GUI
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: r.param.scale
Platform: All | Cpu: All
Comment (by cmbarton):
The problem is the use of floating point spin controls for numeric entry.
You must set the number of significant digits to use this. I don't see
that such spin controls make it any easier for users to enter numbers in a
field than simply typing what is needed. And the number of significant
digits can vary quite a bit among different modules.
IMHO, we should remove this control from the interface unless it actually
is helpful somewhere.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1070#comment:1>
