[GRASS-dev] Re: [GRASS GIS] #1051: wxgui: SEARCH_PATH corruption
GRASS GIS trac at osgeo.org
Sun May 16 20:33:48 EDT 2010
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-releasebranch64
Resolution:            |    Keywords:  mapsets
  Platform:  All       |         Cpu:  All
Changes (by hamish):
  * keywords:  => mapsets
Comment:
 Replying to [comment:5 glynn]:
 > The search path shouldn't really be relevant for the GUI, which
 > should always be using qualified map names.
 as a complete aside, for a while I've had the wish to clean that up a bit
 in the wx GUI as I find it rather cluttering and hard to read.
 perhaps:
 `roads @ PERMANENT`
 or
 `roads (PERMANENT)`
 both in the map layer-list and in the list of maps selector. or maybe just
 omit it in the map-selector pull-down list as it is already given by the
 higher level mapset name in the mapset tree (blue text).
 ... and pack the `(opacity: 100%) [:]` stuff on the right edge of the row.
 thoughts?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1051#comment:6>
