[GRASS-dev] Re: [GRASS GIS] #1070: cannot enter useful values to r.param.scale curvature tolerance in wxPython GUI
GRASS GIS trac at osgeo.org
Sun May 16 23:26:18 EDT 2010
GUI
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  unspecified
Resolution:            |    Keywords:  r.param.scale
  Platform:  All       |         Cpu:  All
Comment (by cmbarton):
 You are right about integers vs. floating point here. Thinking about it,
 and the go round with UTM zones awhile back, I'm coming to the conclusion
 that spin controls are most appropriate where a user needs to move through
 a lot of related values quickly, seeing the result of each value as it
 spins by. The best example would be where spinning would shift a display
 in some dimension. In cases where different values need to be entered only
 occasionally--to set a value and run a module as in this case--then simply
 typing a value is quicker.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1070#comment:3>
