[GRASS-dev] GRASS 7 not compiling on Mac OSX 10.6
Michael Barton
Michael.Barton at asu.edu
Mon May 17 19:38:24 EDT 2010
Thanks Glynn,
I installed ctypesgen.py quite easily. Compiling with the most recent SVN version worked fine.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 17, 2010, at 4:35 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> I just updated from the CVS and tried to compile. I got errors at
>> the end. I'm pretty sure that the ../gui/wxpython error is just a
>> problem with the make file. But the ../lib/python error is something
>> else. Here is the result.
>> Errors in:
>> /Users/cmbarton/grass_dev/grass70_dev/lib/python
>> /Users/cmbarton/grass_dev/grass70_dev/gui/wxpython
>> cmb-mbp:grass70_dev cmbarton$ cd /Users/cmbarton/grass_dev/grass70_dev/lib/python
>> cmb-mbp:python cmbarton$ make
>> make -C ctypes
>> make[2]: ctypesgen.py: No such file or directory
> This should now be ignored.
> 7.0 now uses ctypesgen to generate Python wrappers for the libraries,
> rather than SWIG; you only need it if you want the wrappers (they are
> needed for the wxGUI NVIZ module, though; there probably needs to be a
> conditional import somewhere).
> For more information, see:
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Subject: Re: [GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example
>> [SEC=UNCLASSIFIED]
>> Date: Mon, 17 May 2010 17:01:23 +0100
>> Message-ID: <19441.26707.489147.570557 at cerise.gclements.plus.com>
