[GRASS-dev] Re: [GRASS GIS] #1016: v.info support for level 1
(patch)
trac at osgeo.org
Tue May 18 09:50:00 EDT 2010
#1016: v.info support for level 1 (patch)
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.info
Platform: All | Cpu: All
Comment (by mmetz):
Replying to [comment:1 hamish]:
> is it not possible to have the level automatically detected instead of
requiring to use an extra flag?
> If you had level 2 topo, I don't see why you'd want to force opening at
level 1 for v.info.
Right. v.info no longer needs level 2, it tries level 2 first, if this is
not successful, it tries level 1.
There is also no need to force level 1 just to speed up things, because
v.info opens vectors with head only when trying level 2. At least this is
the original behaviour in 6.4 and earlier, it was changed recently for 6.5
and 7, I changed it back to head only. There is no need to fully open a
vector if level 2 is available.
In short, whatever happens, v.info is lightening fast and uses nearly no
memory. The level 1 option can go.
Um, v.info is fast on cli but slow when used within wxGUI with a large
vector, but that's a wxGUI thing, wxGUI collects some vector information
first before it allows you to run a module.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1016#comment:2>
