[GRASS-dev] diglib test.c fails on 64bit win
Markus Metz
markus.metz.giswork at googlemail.com
Tue May 18 10:34:16 EDT 2010
Glynn Clements wrote:
> Markus Metz wrote:
> In 6.x, LFS is enabled for specific libraries or modules using e.g.:
> ifneq ($(USE_LARGEFILES),)
> EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
> endif
> in the corresponding Makefile. This needs to be done on a case-by-case
> basis because not all modules are LFS-aware, e.g. because they
> calculate offsets using "int" or "long" arithmetic, or use
> fseek/ftell.
IOW, for 6.x and mingw32, each module would need to decide if it wants
to use e.g. fseeko64 or fseek.
> In 7.x, LFS is enabled globally by the following in Grass.make:
> ifdef USE_LARGEFILES
> LFS_CFLAGS = -D_FILE_OFFSET_BITS=64
> endif
I know, I've put that there initially for vector LFS in r37943, you
recycled that in r40620 for global LFS.
> POSIX defines 3 feature-test macros:
> _LARGEFILE_SOURCE
> _LARGEFILE64_SOURCE
> _FILE_OFFSET_BITS
[snip]
> MinGW doesn't have any of these. Instead, the 64-bit names are visible
> unless __NO_MINGW_LFS is defined. There are no fseeko/ftello functions
> (only fseeko64/ftello64), and no equivalent of _FILE_OFFSET_BITS.
So, how about
--- config.h.in (revision 42291)
+++ config.h.in (working copy)
@@ -259,8 +259,6 @@
* Defines needed to get large file support - from cdrtools-2.01
-#ifdef USE_LARGEFILES
#undef HAVE_LARGEFILES
#ifdef HAVE_LARGEFILES /* If we have working largefiles at all */
@@ -279,13 +277,18 @@
/* defined, we have fseeko() */
#ifdef __MINGW32__
+/* add/remove as needed */
#define off_t off64_t
#define fseeko fseeko64
#define ftello ftello64
+#define lseek lseek64
+#define tell tell64
+#define seek seek64
+#define stat stat64
+#define fstat fstat64
#endif
#endif /* HAVE_LARGEFILES */
-#endif /* USE_LARGEFILES */
/* define if langinfo.h exists */
#undef HAVE_LANGINFO_H
