[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example
[SEC=UNCLASSIFIED]
Martin Landa
landa.martin at gmail.com
Tue May 18 13:18:19 EDT 2010
2010/5/18 Glynn Clements <glynn at gclements.plus.com>:
> Odd. Can you try it under GDB and check what arguments
> G_find_raster2() is getting?
> Also, are you calling G_gisinit() first?
sample script below
#!/usr/bin/env python
import os, sys
from grass.lib import grass, raster
from ctypes import *
input = sys.argv[1]
grass.G_gisinit(sys.argv[0])
mapset = grass.G_find_raster2(input, "")
print mapset
Running
python example.py elevation
I get
D1/5: G_find_raster2(): name=� ��� mapset=elevation
WARNING: Illegal filename <� ���>. Character <� not allowed.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
