[GRASS-dev] [GRASS GIS] #1074: $GRASS_BATCH_JOB isn't executed
trac at osgeo.org
Wed May 19 13:30:35 EDT 2010
Reporter: martin | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
GRASS SVN trunk is installed into /opt/GRASS70/ (analogously to the one in
#491). I've copied a rudimentary $GISDBASE and ~/.grass7/rc from another
machine which is capable of running a GUI. GRASS_GUI is set to text in the
rc file.
hypersphere: 10:15:36 ~> pwd
/home/martin
hypersphere: 10:15:37 ~> ls -l landcover/grassimport_pg.sh
-rwxr-xr-x 1 martin users 6590 19. Mai 09:51 landcover/grassimport_pg.sh
hypersphere: 10:15:40 ~> head -1 landcover/grassimport_pg.sh
v.in.ogr dsn="PG:host=zuluviz.optiputer.net dbname=landcover user=webuser"
layer=cstest_agroforest output=cstest_agroforest
Ok, now:
hypersphere: 10:15:44 ~> env
LOCATION=/home/martin/grassdata/world/PERMANENT
GRASS_BATCH_JOB=/home/martin/landcover/grassimport_pg.sh
/opt/GRASS70/bin/grass70
Cleaning up temporary files...
Starting GRASS GIS...
Executing '/home/martin/landcover/grassimport_pg.sh' ...
Welcome to GRASS 7.0.svn (2010)
[... nothing happens ...]
hypersphere /home/martin> exit
exit
Batch job '/home/martin/landcover/grassimport_pg.sh' (defined in
GRASS_BATCH_JOB variable) was executed.
Goodbye from GRASS GIS
Actually almost everything is fine - just the $GRASS_BATCH_JOB script
doesn't get executed as promised. When copying script lines into the GRASS
command prompt, they're being processed nicely.
Same batch setup worked perfectly with GRASS64 and I didn't encounter any
differences in the HTML manual pages, therefore I decided to file a bug.
Cheers, Martin.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1074>
