[GRASS-dev] Re: i.pr in GRASS6.4
António Rocha
antonio.rocha at deimos.com.pt
Thu May 20 03:45:32 EDT 2010
Hi Markus
Ok I finally managed to understand better what is happening.
i.pr.Training- Interactive option is failing. Non-interactive requires
GRASS sites points. So far, I was able to do a testing dataset using
interactive. What is failing in interactive? Not displaying image
i.pr.features- I fixed what was not working
i.pr.model- I believe it's working
i.pr.classification- Not working, at least for kNN. Doind some debugging...
> Subject:
> Re: [GRASS-dev] Re: i.pr in GRASS6.4
> From:
> Markus Neteler <markus.neteler at iasma.it>
> Date:
> Wed, 19 May 2010 12:23:49 +0200
> To:
> grass-dev at lists.osgeo.org
> To:
> The MAN manual building script is either not existing on
> your machine or perl fails:
> GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
> /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
> /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html
> /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
> sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
> make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
> That's harmless for the usage.
> For the rest, there are warnings which should ideally be fixed but
> warnings are not necessarily errors.
> Perhaps you would just try the tools?
> Markus
> On 05/18/2010 04:41 PM, António Rocha wrote:
>> Ups forgot the attachment.. Sorry
>> All executables were created...
>>> I'm sorry but I need to make a correction regarding this. This was
>>> done for GRASS6 so Makefiles will be similar to the ones that
>>> GRASS6.4 has.
>>> Ok I have downloaded i.pr into my LINUX (Ubuntu machine) and I've
>>> used this command to compile:
>>> sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
>>> Attached to this email is the installation LOG. I had a few errors,
>>> regarding Description.html but how is the rest? OK?
>>> (will it work on GRASS6.4?)
>>> Thank you
>>> best regards,
>>> Antonio Rocha
>>>> Greetings all
>>>> I've seen a few emails, at GRASS users mailing list regarding i.pr
>>>> module. This module, developed for GRASS5 by Stefano Merler , is a
>>>> multi-tool to perform Classification for a wide set of methods.
>>>> This is a good asset for GRASS having this tool "fully working" on
>>>> GRASS 6.4.
>>>> has anyone tried to "redone" this tool to GRASS6.4.?
>>>> Thank you so much for your help
>>>> Best regards,
>>>> Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5130 (20100519) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
