[GRASS-dev] Re: [GRASS GIS] #1074: $GRASS_BATCH_JOB isn't executed
GRASS GIS trac at osgeo.org
Fri May 21 01:25:55 EDT 2010
  Reporter:  martin  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  7.0.0
 Component:  Python  |     Version:  svn-trunk
Resolution:          |    Keywords:  startup
  Platform:  Linux   |         Cpu:  x86-64
Changes (by hamish):
  * keywords:  => startup
Comment:
 One thing I've wanted to see for a long time, and grass7 init.py is a
 great opportunity for, is to have better parsing of command line options
 than grass 6's init.sh has. Maybe I'm just used to how good G_parser() is
 by comparison..
 Anyway, it would be great to be able to pass the batch job script filename
 as a command line option to init.py instead of having to mess with special
 environment variable hacks etc. to get it to work.
 thanks,
 Hamish
 ps- any objections/comments to adding a "startup" component in trac?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1074#comment:2>
