[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example
[SEC=UNCLASSIFIED]
Martin Landa
landa.martin at gmail.com
Fri May 21 03:37:31 EDT 2010
2010/5/20 Glynn Clements <glynn at gclements.plus.com>:
> Does this work:
> c_input = c_char_p(input)
> c_mapset = c_char_p("")
> mapset = grass.G_find_raster2(c_input, c_mapset)
No,
String.from_param(): $Revision: 41297 $
String.__init__(): $Revision: 41297 $
String.from_param(): /home/martin/smetiste/example7.py
String.__init__(): /home/martin/smetiste/example7.py
File "/home/martin/smetiste/example7.py", line 10, in <module>
ctypes.ArgumentError: argument 1: <type 'exceptions.TypeError'>:
cannot concatenate 'str' and 'c_char_p' objects
> Or this:
> grass.G_find_raster2.argtypes = [c_char_p, c_char_p]
> grass.G_find_raster2.restype = c_char_p
Yes, it's working.
> The most common issue with ctypes, and the most likely reason why the
> underlying function would end up getting garbage data, is that the
> ctypes pointer types don't hold a reference to the underlying object,
> which can result in it being garbage collected while it is still being
> used.
Yes, it's seems to be a ctypes issue.
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
