[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example
[SEC=UNCLASSIFIED]
Martin Landa
landa.martin at gmail.com
Sun May 23 13:55:28 EDT 2010
2010/5/21 Glynn Clements <glynn at gclements.plus.com>:
>> Yes, it's seems to be a ctypes issue.
> Well, the "manual" ctypes version worked earlier, so it appears to be
> a problem with the wrappers. The preamble's String type looks
> unnecessarily complex; there's probably a reason, but I have doubts as
> to whether the benefits outweight the drawbacks.
> Can you try r42331? This eliminates most of the preamble, making
> String and ReturnString aliases for c_char_p. If there's a need for
> something more complex, I'll deal with that if and when it happens.
Sample script:
#!/usr/bin/env python
import os, sys
from grass.lib import grass
from ctypes import *
grass.G_gisinit(sys.argv[0])
mapset = grass.G_find_raster2("elevation", "")
print mapset
Result:
File "/home/martin/smetiste/example7.py", line 8, in <module>
TypeError: __init__ expected at most 1 arguments, got 3
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
