[GRASS-dev] grass7 on mac OSX
    Massimo Di Stefano
    massimodisasha at gmail.com
    Sun May 23 18:49:51 EDT 2010
Hi All,
i upgrade grass7 from svn on mac osx 10.6.3 ,
the build ends with an error in wxpython, rerunning make inside the wxpython director fix the problem.
but tring to load grass from python i had thi error :
In [1]: from grass.lib import grass
  File "<ipython console>", line 1, in <module>
  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/python/grass/lib/__init__.py", line 3, in <module>
    # $Id$
  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/python/grass/lib/math.py", line 7, in <module>
ImportError: dlopen(/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so, 2): Symbol not found: _G_math_backward_solving
  Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so
  Expected in: /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gmath.dylib
 in /Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/_math.so
have you any clue on what i'm missing ?
thanks!
Massimo.
