[GRASS-dev] GRASS 7: d.rast.leg bug
Glynn Clements
glynn at gclements.plus.com
Mon May 24 21:04:51 EDT 2010
Markus Neteler wrote:
> using d.rast.leg I got this bug:
> line 77, in make_frame
> (ft, fb, fl, fr) = f
> ValueError: need more than 0 values to unpack
> Any ideas? Will be trivial...
This is a result of d.info failing, which is due to r33172 being
incomplete ("cflag" still exists and is still tested but is no longer
initialised).
Fixed in r42344.
