[GRASS-dev] Re: [GRASS GIS] #1052: Build of 7.0.SVN dont work
trac at osgeo.org
Wed May 26 20:12:19 EDT 2010
Reporter: jeleniste | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by glynn):
Replying to [comment:7 martinl]:
> ...the remaining issue is how to launch correctly the shell, see
[source:grass/trunk/lib/init/grass.py at 42357#L774]. Any hits welcomed...
subprocess.call() is fine, but SHELL isn't normally going to be set on
Windows, so it will need to be set in a batch file prior to running the
grass70.py script (or the script needs -cmd and -sh options to choose the
shell).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1052#comment:8>
