[GRASS-dev] [GRASS GIS] #1079: wxpython GUI error in d.vect
GRASS GIS trac at osgeo.org
Thu May 27 09:23:19 EDT 2010
 Reporter:  Lluis                                                     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                                                    |      Status:  new
 Priority:  critical                                                  |   Milestone:  6.4.0
Component:  wxGUI                                                     |     Version:  6.4.0 RCs
 Keywords:  Display, d.vect, wxpython, add vector layer, no response  |    Platform:  MSWindows XP
      Cpu:  x86-32                                                    |
 When I am starting GRASS ('''wxpython GUI''') in a __Windows OS__, there
 is an error when I try to display a vector map (d.vect) '''using the icon
 on the GUI'''. If I do it through the command line (d.vect roads)
 automatically the vector layer is displayed but, if I try to do it using
 the add vector map layer button, the software hangs itself (is not
 responding)...
 I've downloaded: http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.
 SVN-r42329-1-Setup.exe
 In my ubuntu 9.10 GRASS64 -wxpython it works properly but most of my
 students are Windows users.
 Thanks in advance
 Lluís
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079>
