[GRASS-dev] grass7 on mac OSX
William Kyngesburye
woklist at kyngchaos.com
Thu May 27 09:43:57 EDT 2010
On May 27, 2010, at 3:56 AM, Massimo Di Stefano <massimodisasha at gmail.com
> wrote:
> Hell Soeren,
> seems i've an up-to-date revision :
> MacBook-Pro-15-di-Massimo-Di-Stefano:grass_trunk sasha$ svn up
> At revision 42358.
> i also did make distclean first to re-try configure && make.
> but your note about a "renamed" function, point me to a problem i
> had on qgis side too (make install overwrite the .app but ... it
> don't do it as aspected)
> infact, removing manually the old grass70.app (compiled from source)
> trashing the complete app from /Application , instead of overwrite
> it using "sudo make install"
> now i have :
> In [1]: import os, sys
> In [2]: from grass.lib import raster
> Traceback (most recent call last):
> File "<ipython console>", line 1, in <module>
> ImportError: No module named lib
I wonder if ipython is affecting this? Just a random idea. (I can't
try anything right now- dev Mac died)
> the error is present but changes ... this time maybe can be a wrong
> sintax i used ???
> weird .. i'm a bit confused ;-)
> i'm tring to replicate, from command line, the code :
> import os, sys
> from grass.lib import grass, raster
> from ctypes import *
> input = sys.argv[1]
> grass.G_gisinit(sys.argv[0])
> mapset = grass.G_find_raster2(input, "")
> print mapset
> Massimo
> Il giorno 27/mag/2010, alle ore 10.37, Soeren Gebbert ha scritto:
>> Hello Massimo,
>> can you please make a svn update?The gmath function
>> G_math_backward_solving has been renamed into
>> G_math_backward_substitution a while ago. Maybe something got mixed
>> up?
>> Best
>> Soeren
