[GRASS-dev] Re: [GRASS GIS] #1052: Build of 7.0.SVN dont work
trac at osgeo.org
Fri May 28 15:16:33 EDT 2010
Reporter: jeleniste | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by martinl):
Replying to [comment:11 hellik]:
> at the moment, with the desktop-shortcut "GRASS 7.0.SVN" and the "GRASS
Command Line"-shortcut in the program menue
> (seehttp://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
Installer.nsi#L621)
> you get in both cases a windows-commandline with the following
information:
> This version running through: shell (C:\Program Files\GRASS-70-
SVN\msys\bin\sh.exe)
"GRASS 7.0.svn" (cmd) is working OK. "GRASS 7.0.svn with MSYS" just flash
and nothing happens.
From running MSYS
landa at GEO1 /osgeo4w/usr/src/grass_trunk
$ ./bin.i686-pc-mingw32/grass70 -wx
$ Cleaning up temporary files...
Starting GRASS GIS...
UPOZORNÌNÍ: Attention!
UPOZORNÌNÍ: Locking is not supported on Windows!
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 7.0.svn (2010)
GRASS homepage: http://grass.osgeo.org
(C:\OSGeo4W\apps\msys\bin\sh.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Done.
Goodbye from GRASS GIS
File "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-
mingw32\etc\gui\wxpython\wxg ui.py", line
73, in <module>
import gui_modules.preferences as preferences
File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
mingw32/etc/gui/wxpython/gui
_modules/preferences.py", line 857, in <module>
globalSettings = Settings()
_modules/preferences.py", line 545, in __init__
self.ReadSettingsFile()
_modules/preferences.py", line 610, in ReadSettingsFile
gisdbase = gisenv['GISDBASE']
Ticket URL: <http://trac.osgeo.org/grass/ticket/1052#comment:12>
