[GRASS-dev] Re: [GRASS GIS] #1020: Display of vector maps fails
trac at osgeo.org
Sun May 30 06:30:00 EDT 2010
Reporter: MilenaN | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows 7 | Cpu: x86-64
Comment (by martinl):
Replying to [ticket:1020 MilenaN]:
> GRASS freezes when trying to open a vector map. Both Apply and OK
buttons has been tested.
> Raster maps can be opened with no problem.
I have similar problem on MS Windows 2008.
Running GRASS locally from MSYS works, i.e. I can display a vector map.
landa at GEO1 /osgeo4w/usr/src/grass64_release
$ ./bin.i686-pc-mingw32/grass64 -wx
Running installed version, GRASS freezes when displaying a vector map.
Reason is {{{db.describe}}} command which is launched on the background.
GUI D1/1: gcmd.Command(): db.describe -c --q table=archsites driver=dbf
database=C:\Users\landa\grass data/spearfish60/PERMANENT/dbf/
UPOZORNÌNÍ: Nelze spustit pøíkaz
When running manually from MSYS
GRASS 6.4> db.describe -c --q table=archsites driver=dbf
database="C:\Users\landa\grass data/spearfish60/PERMANENT/dbf/"
Bad file descriptor: Files
The same command works when running the command from OSGeo MSYS
ncols: 2
nrows: 25
Column 1: cat:INTEGER:11
Column 2: str1:CHARACTER:30
Any pointers?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1020#comment:4>
