[GRASS-dev] Re: [GRASS GIS] #1079: wxpython GUI error in d.vect
trac at osgeo.org
Sun May 30 06:51:47 EDT 2010
Reporter: Lluis | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: Display, d.vect, wxpython, add vector layer, no response
Platform: MSWindows XP | Cpu: x86-32
Comment (by martinl):
Replying to [ticket:1079 Lluis]:
> When I am starting GRASS ('''wxpython GUI''') in a __Windows OS__, there
is an error when I try to display a vector map (d.vect) '''using the icon
on the GUI'''. If I do it through the command line (d.vect roads)
automatically the vector layer is displayed but, if I try to do it using
the add vector map layer button, the software hangs itself (is not
responding)...
> I've downloaded: http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.
SVN-r42329-1-Setup.exe
Are you running from MSYS or CMD? Seems to be duplicate of #1020.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079#comment:2>
