[GRASS-dev] Re: [GRASS GIS] #1020: Display of vector maps fails
trac at osgeo.org
Sun May 30 18:09:47 EDT 2010
Reporter: MilenaN | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows 7 | Cpu: x86-64
Comment (by hamish):
is "C:\Program Files (x86)" common for 64bit Windows7 or a local install
choice? Including $arch there is something new to me. Is that $arch seen
with Vista 64bit too?
> seems to be problem with _spawnl
> grass/branches/releasebranch_6_4/lib/db/dbmi_client/start.c at 41132#L221
apparently so.
that is the only place in the 6.4 code that uses _spawnl(), although
lib/gis/system.c uses, and comments in g.parser speak of _spawnlp().
one obvious thing is that in the non-osgeo4w install the `startup` string
does is missing an executable name (which must end in .exe for _spawnl()
too), it is just the dir. (but where is the closing "]" on that string
too?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1020#comment:8>
