[GRASS-dev] Re: [GRASS GIS] #1020: Display of vector maps fails
trac at osgeo.org
Sun May 30 22:00:43 EDT 2010
Reporter: MilenaN | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows 7 | Cpu: x86-64
Comment (by glynn):
Replying to [comment:7 martinl]:
> seems to be problem with _spawnl
Yep. _spawnl() simply concatenates its arguments, with spaces between
them; it doesn't perform any quoting.
An example of "correct" quoting can be found in escape_arg() in
lib/gis/spawn.c. "correct" in quotes because it's up to the C runtime as
to how to parse the command line into individual arguments; the
escape_arg() function matches the MSVC behaviour, and is the same
algorithm as used by e.g. Python's subprocess module (see list2cmdline()
in subprocess.py).
MSDN reference: http://msdn.microsoft.com/en-us/library/17w5ykft.aspx
Ticket URL: <https://trac.osgeo.org/grass/ticket/1020#comment:9>
