[GRASS-dev] r4415 - store grass libs in ./lib instead of ./extralib
Martin Landa landa.martin at gmail.com
Sat Nov 6 17:46:55 EDT 2010
2010/11/6 Helmut Kudrnovsky <hellik at web.de>:
> shouldn't ./lib-path be added to $INSTALL_DIR\${GRASS_COMMAND}.bat
> (http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi#L656)
> and $INSTALL_DIR\bin\${GRASS_COMMAND}
> (http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi#L777)?
the PATH is used for utilities which can be used by GRASS. From this
point of view GRASS libs are not required to be in the path.
my 2 cents, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
