[GRASS-dev] Re: [GRASS-SVN] r44252 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
Yann Chemin
yann.chemin at gmail.com
Mon Nov 8 15:04:00 EST 2010
>From what I can read if no file descriptor is found then do not
convert meters to km
If no file descriptor is found it should fall back to a single
altitude value found in the input parameter file, the crux is that the
value is in meters too...
A good modification would be to remove elevation (ialt) value from
parameter file and make it a separate input value to clarify the issue
value Vs raster input file. Likewise for visibility (ivis).
Yann Chemin
www.csu.edu.au
On 09/11/2010, at 4:43, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Nov 8, 2010 at 10:28 AM, <svn_grass at osgeo.org> wrote:
>> grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp
>> grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
>> Log:
>> i.atcorr: be less verbose, fix when elevation is not given
>> (merge r44250 from devbr6)
> Just curious about this change:
>> Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
>> --- grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp 2010-11-08 09:27:08 UTC (rev 44251)
>> +++ grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp 2010-11-08 09:28:04 UTC (rev 44252)
>> @@ -331,7 +330,8 @@
>> G_set_f_null_value(&buf[col], 1);
>> continue;
>> - alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
>> + if (ialt_fd >= 0)
>> + alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
>> /* check if both maps are active and if whether any value has changed */
>> if((ialt_fd >= 0) && (ivis_fd >= 0) && ((prev_vis != vis[col]) || (prev_alt != alt[col])))
> If no elevation is available, perhaps better issue a warning/fatal error?
> I am not very familiar with this code so I dunno but in general
> performing atmospheric
> correction without DEM can lead to nonsense. But perhaps my observation is
> not applicable in this code chunk.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
