[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
trac at osgeo.org
Thu Nov 11 03:21:27 EST 2010
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
Running r.li.edgedensity in 6.4.svn, we obtain a segmentation fault.
The input map corine_1_2000_nonull contains a ring-like area surrounded by
-1 cells and -1 in the center (if that matters):
(gdb) r map=corine_1_2000_nonull conf=corine_1_2000
output=corine_1_2000_edge
Starting program: /usr/local/grass-6.4.1svn/bin/r.li.edgedensity
map=corine_1_2000_nonull conf=corine_1_2000 output=corine_1_2000_edge
Detaching after fork from child process 30690.
Detaching after fork from child process 30691.
Detaching after fork from child process 30692.
Detaching after fork from child process 30693.
Detaching after fork from child process 30694.
Detaching after fork from child process 30695.
Detaching after fork from child process 30696.
Detaching after fork from child process 30697.
Detaching after fork from child process 30698.
Detaching after fork from child process 30699.
Program received signal SIGSEGV, Segmentation fault.
0x00002aaaaaf42655 in next_Area (parsed=1, l=0x604690, g=0x6046b0,
m=0x7fffffffadc0) at daemon.c:651
651 memcpy(&tmp, l->head->m, sizeof(msg));
(gdb) bt full
#0 0x00002aaaaaf42655 in next_Area (parsed=1, l=0x604690, g=0x6046b0,
tmp = {type = 2, f = {f_a = {aid = 2, x = 0, y = 0, rl = 147, cl =
295}, f_ma = {aid = 2, x = 0,
y = 0, rl = 147, cl = 295,
mask = "corine_1_2000", '\000' <repeats 191 times>"\324,
.\364\252\252*", '\000' <repeats 14 times>,
"\001\000\000\000\300\255\377\377\377\177\000\000\000\000\000\000\006",
'\000' <repeats 14 times>}, f_d = {aid = 2, pid = 0, res =
3.1193338127189503e-312}, f_e = {aid = 2, pid = 0}, f_t = {pid = 2}}}
#1 0x00002aaaaaf40845 in calculateIndex (file=0x604250 "corine_1_2000",
f=0x401238 <edgedensity>,
parameters=0x0, raster=0x604230 "corine_1_2000_nonull",
output=0x604270 "corine_1_2000_edge")
at daemon.c:156
pathSetup =
"/home/lucadelu/.r.li/history/corine_1_2000\000\000\000\000\000\000/grassdata/eu_laea/slovenia",
'\000' <repeats 77 times>, "Xڀh<", '\000' <repeats 11 times>"\250,
\331\363\252\252*\000\000h8\300i<\000\000\000'|\200h<", '\000' <repeats 67
times>, "\001", '\000' <repeats 23 times>, "\037a\200h<", '\000' <repeats
70 times>, "j<\000\000\000\000
\000j<\000\000\000\224\037\000j<\000\000\000\224\037\000j<", '\000'
<repeats 11 times>, "Xڀh<\000\000\000\000
j<\000\000\000\250\331\363\252\252*\000\000\363"...
out =
"/home/lucadelu/.r.li/output/corine_1_2000_edge\000\000\033", '\000'
<repeats 11 times>"\377, \377\377\377\034\036\260\252\252*", '\000'
<repeats 946 times>"\300,
\314\377\377\377\177\000\000\266\070\260\252\252*\000\000\266\070\260\252\252*\000\000\a\000\000\000\000\000\000\000?5\204i<\000\000\000\020\000\000\000\060\000\000\000@\311\377\377\377\177\000\000\200\310\377\377\377\177\000\000\266\070\260\252\252*\000\000\a\000\000\000\000\000\000\000?5\204i<\000\000\000\b\000\000\000\000\000\000\000\260\314\377\377\377\177\000\000\020\000\000\000\060\000\000\000\200\311\377\377\377\177\000\000\300\310\377\377\377\177\000\000\035\036\260\252\252*\000\000\b\000\000\000\000\000\000\000?5\204i<\000\000\000\261\070\260\252\252*\000\000'\214\200h<\000\000\000\030\036\260\252\252*\000\000\330v\024\253\252*\000\000\006\000\000\000\000\000\000\000"...
parsed = 1 '\001'
reportChannelName = 0x604710
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.0"
random_access_name = 0x3c68a1bbc0 ""
history = {mapid = '\000' <repeats 79 times>, title = '\000'
<repeats 79 times>,
mapset = '\000' <repeats 79 times>, creator = '\000' <repeats 79
times>,
maptype = '\000' <repeats 79 times>, datsrc_1 = '\000' <repeats
79 times>,
datsrc_2 = '\000' <repeats 79 times>, keywrd = '\000' <repeats
79 times>, edlinecnt = 0,
edhist = {'\000' <repeats 79 times> <repeats 45 times>,
"\000\000\000\000\060\307\377\377\377\177\000\000\266\070\260\252\252*\000\000\266\070\260\252\252*\000\000\a\000\000\000\000\000\000\000?5\204i<",
'\000' <repeats 11 times>"\360,
\306\377\377\377\177\000\000\000\000\000\000\000\000\000\000p\307\377\377\377\177\000\000\035\036\260\252",
"\252*\000\000\035\036\260\252\252*\000\000\b\000\000\000\000\000\000\000?5\204i<\000\000\000\261\070\260\252\252*\000\000\060\307\377\377\377\177\000\000\000\000\000\000\000\000\000\000P\302\377\377\377\177",
'\000' <repeats 18 times>"\377, \377\377\377",
"\377\377\377\377\240\310\377\377\377\177\000\000\030\036\260\252\252*\000\000\200\307\377\377\377\177\000\000\000\000\000\000\001",
'\000' <repeats 27 times>"\377,
\377\377\377\377\377\377\377\030\036\260\252\252*\000\000\000\000\000",
"\000\000\000\000\070\306\377\377\377\177\000\000
\000\000\000\001", '\000' <repeats 59 times>, " \000\000", '\000' <repeats
15 times>, "s", '\000' <repeats 60 times>, "\022\000\000"}}
g = 0x6046b0
receiveChannel = 15
res = 16
child = {{pid = 30690, pipe = 0x604750
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.1",
channel = 5}, {pid = 30691,
pipe = 0x604790
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.2", channel = 6}, {
pid = 30692, pipe = 0x6047d0
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.3",
channel = 7}, {pid = 30693,
pipe = 0x604810
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.4", channel = 8}, {
pid = 30694, pipe = 0x604850
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.5",
channel = 9}, {pid = 30695,
pipe = 0x604890
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.6", channel = 10}, {
pid = 30696, pipe = 0x6048d0
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.7",
channel = 11}, {pid = 30697,
pipe = 0x604910
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.8", channel = 12}, {
pid = 30698, pipe = 0x604950
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.9",
channel = 13}, {pid = 30699,
pipe = 0x604990
"/grassdata/eu_laea/slovenia/.tmp/blade06/30687.10", channel = 14}}
i = 2
mypid = 30687
doneDir = -1
withoutJob = 32767
mv_fd = 1753295058
random_access = 60
l = 0x604690
m = {type = 2, f = {f_a = {aid = 2, x = 0, y = 0, rl = 147, cl =
y = 0, rl = 147, cl = 295, mask = "corine_1_2000", '\000'
<repeats 242 times>}, f_d = {
aid = 2, pid = 0, res = 3.1193338127189503e-312}, f_e = {aid
pid = 2}}}
doneJob = {type = 0, f = {f_a = {aid = 0, x = 0, y = 0, rl = 0, cl
= 0}, f_ma = {aid = 0, x = 0,
y = 0, rl = 0, cl = 0, mask = '\000' <repeats 255 times>},
f_d = {aid = 0, pid = 0,
res = 0}, f_e = {aid = 0, pid = 0}, f_t = {pid = 0}}}
testpath = "/home/lucadelu/.r.li/history/", '\000' <repeats 4066
times>
#2 0x0000000000401236 in main (argc=4, argv=0x7fffffffe3c8) at
edgedensity.c:72
raster = 0x2aaaaad14ee0
conf = 0x604090
output = 0x604150
class = 0x604470
module = 0x2aaaaad14f80
par = 0x0
(gdb)
Any ideas what's wrong in raster/r.li/r.li.daemon/daemon.c ?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/1214>
