[GRASS-dev] r.distance: 'maps=map1,map2' vs 'maps=map1 maps=map2'
Maciej Sieczka
msieczka at sieczka.org
Thu Nov 11 12:22:53 EST 2010
I have discovered an undocumented feature (?) in r.distance.
The manual reads:
r.distance maps=map1,map2
When I specify it as:
r.distance maps=map1 maps=map2
it works as well.
The order can also be controlled this way. I.e.:
r.distance maps=map1,map2 is equivalent to r.distance maps=map1 maps=map2
and:
r.distance maps=map2,map1 is equivalent to r.distance maps=map2 maps=map1
Can I rely on this behavior or may it change in future? Currently it
works for 6.4 svn and 7 svn.
Maciek
Maciej Sieczka
http://www.sieczka.org
