[GRASS-dev] [GRASS GIS] #1215: db.tables in Windows layer manager does not populate driver field for pg
GRASS GIS trac at osgeo.org
Sat Nov 13 06:37:44 EST 2010
 Reporter:  foconnor             |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  minor                |   Milestone:  6.4.1
Component:  Default              |     Version:  6.4.0
 Keywords:  wingrass, db.tables  |    Platform:  MSWindows 7
      Cpu:  x86-32               |
 When using the layer manager in Windows, and selecting Database | Database
 Information | List Tables, the command that is created does not include
 'driver=pg' and as a result the command fails to run.
 All other options for 'driver= ' populate the command correctly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1215>
